Here is my try. Nice photo. Lifted shadows a bit.
Thomas
By the number - Thomas
Thomas,
You might want to try to find a better shadow point. The image looks flat because you have two adjustments close together in the tonal range. The strength of RGB is the fact that you can have separate neutrals based on the brightness. The "trap" so to speak is thinking neutral means Gray.
REMEMBER: White and Black can be and are neutral colors just as well as Gray can be.
