Did same procedure as Gary and as described in hints. Not quite sure why you have to apply after shadow point set but guess that otherwise the fixed point will lock adjustments in shadows of the RGB channels (dragging curve to the right)?
Have a question. In my Hue Clocks I have the same Hue in shadows as on brighter locations on the church, Clock on 1. In the hints given the Hue for the shadows should show 2.30, why not the same that is 1?
Thomas
Example 7 St Vitus2 - Thomas
