Example 6 St. Vitus_Gary
Gary
Postby Gary » Wed Feb 04, 2009 10:55 pm
Here is my example 6, did it in RGB seemed simple enough played with both ends of the blue channel till I got about the same as  the example shows, not sure I may be missing something here as I notice in one reply you  made to Thomas you are in LAB using the lightness curve.
I am still struggling with example 5.
On my computer I am unable to reduce Curvemeister to the task bar on its own, does this work on yours?
Gary
Postby ggroess » Thu Feb 05, 2009 1:06 am
CM can get "lost" if you minimize it.   If you have PS you can invoke it as a smart filter so that you can return from PS at a later time.
We will be covering that later in the course.
You image looks good.  I used the L curve on the other image to save the highlight side of the image which appeared to be too bright.
