Advanced Skin Tones Workflow....
Postby ggroess » Sun Feb 01, 2009 5:30 pm
As I work on skin tones in CM one of the biggest hurdles is knowing what "Skin Pin" to set.  I have created a few resources for you to use and build upon.
Lastly is the work flow...
