What is the name of this animal? Here is my try. Used pin 1. Question: When to use other skin pins?
Thomas
Skin tone animal
Thomas,
check out the skin tones work flow and see the additional pins file posted. There are many times to use the additional pins....
Your Proboscis Monkey looks great.
Play with a neutral a bit on the fur of the forearm and see if you get any better results I thought you did very well but again this is a judgment call there is more in the image to recover...
