Taroko Gorge - kessi
kessi
Postby kessi » Sat Jan 31, 2009 9:06 pm
I did very little adjusting in Lab. I moved the light and dark thresholds until I could just see the white and black bits appearing.
I used the neutral on the rocks in the right hand corner. It seemed to  give it a glow from the invisible sun. I got the hint from Thomas's picture. I also increased the a and b to 1.51.
kessi
Postby ggroess » Sat Jan 31, 2009 9:18 pm
Very nice....
Did you play with the color saturation more than the setting listed??
Just curious
kessi
Postby kessi » Sun Feb 01, 2009 10:40 am
I probably didn't list everything. Here is the screenshot. Everything done in CM.
kessi
Postby ggroess » Sun Feb 01, 2009 5:19 pm
It looks very moody which is nice but the water is a bit too blue.  You can go after this in RGB if you like or leave it alone your choice...
