Example 7 Taroko Gorge_Gary
Gary
Postby Gary » Tue Jan 27, 2009 9:49 pm
I used the white water for the highlight and neutral, and for shadow I used a shadow on the rock cliff. Worked in LAB. I do notice that there will be blown out areas in the water,
Gary
Gary
Postby Gary » Wed Jan 28, 2009 12:14 am
Going to do a remake after seeing the second one Thomas did which I see is much better.
Gary
Gary
Postby Gary » Wed Jan 28, 2009 10:17 pm
Used the cliff for shadow, and the white water for highlight and neutral, the changed the shadow curve to lesson the brightness.
Gary
Postby ggroess » Thu Jan 29, 2009 2:00 am
Gary,
I think you went too far with the highlight threshold.  see screen shot.  Try to go for some compromise where you just start to see the white dots appear.  Shot 2
Also fear not the saturation slider in LAB...it is your friend....
