Greg:
As you can see, the link you sent me did the trick. Here is my effort at the Dragon. Drawing from an earlier lesson, I used the foam in the upper right side of the picture as my neutral. I used a gray from the concrete on the left side of the dragon first, but didn't like what it did to the color of the dragon. The foam I thought did a pretty good job.
Brian
Dragon from Mars
Brian,
You need to find a point on the dragon where he seems to be fairly neutral not perfect but semi normal...Ctrl click this point not a neutral setting just a pinned control point on the curve. This is where the rotation happens. It should help keep the dragon the right color.
You need not set a neutral on this one...
