After performing adjustments in CM LAB mode, as we have learned, I had to try some further adjustments in PSE. Not so easy as I do not believe photo quality is too high. Selected heaven and applied a blue gradient. After that I slightly colorized sea. And in the end some unsharp mask as learned. Hope you apologize these corrections.
Thomas
Example 4-Orthodox building?
I fixed colors by setting Shadow Highlight and Neutral in RGB. I used Dust and Scratches on Red and Blue channel to kill noise and small detail then Unsharp mask. Dark blue for sky, seems like it is winter. The building reminds of Russia. St. Peterburg for instance, but I think there is a piece of USA flag on right side.
