Flower Vendor
I toyed around with this so much, I can't recall everything I did. The version before this ended up with what looked like a slight yellow color cast on the walls behind the vendor. That might be accurate, but I wasn't sure so I wanted to make the walls look a little more like graystone. The best way I found to do that was a slight desaturation in HSB,which helped.
