How to post images to the class board
Postby ggroess » Mon Dec 29, 2008 5:19 pm
Everyone,
  • Please remember to re-size your images to fit under the 200kb limit per image.
    You can have up to 500kb per post but no more than 200kb per attached image.
  • If you are new to image re-sizing you can use the PS or PSE "save for web" command under the "file" menu to help you re-size the image.  You might want to keep the overall image size to 1024X1024 as upper limits for both horizontal and vertical sizes.  Just set the quality value to give you an Image that is less than 200kb.
  • You might want to look into a freeware printscreen program.  I use Gadwin Printscreen
http://www.gadwin.com/printscreen/ version 4.3 is free. This will help you capture screens that include the curves windows and to help us work with you on your images.
    Addendum...It helps when the moderators can add images as well...Sorry I missed the image files for you all...Spelling is also on of my minor handicaps...
    j2e4a8n
    Postby j2e4a8n » Wed Jan 14, 2009 3:36 pm
    Hi,
    I have a trouble with print screen.
    While I was taking the september class, it was working perfectly. But now I have a window xp 'Print screen has encounter a problem'.
    Maybe the updates created the problem
    Jean Pierre
    Postby ggroess » Wed Jan 14, 2009 3:40 pm
    hmmm...Mine functions correctly...you might want to re-install the print screen program....
    j2e4a8n
    Postby j2e4a8n » Fri Jan 16, 2009 5:42 pm
    I have uninstaled 4.3 and reinstalled 4.4.
    Before posting
