Did a "by the numbers" adjustment in RGB. (That technique really appeals to me for some reason.) Then a second pass in Lab with a b mask. So this time the cyan fur is minimized.
Lemur Makeup
um...a bit too far....
I took your image and added a neutral. See screen shot.
I have also included the ACV file. Save it to your desktop and then you can open your image in CM and load this file. Unless you monitor is really out of adjustment for color I'm afraid you went too far with this Brian....
