Sun Moon Lake Temple View (B Mask)
This was curved with the alternate solution using a B channel mask. I took a first pass in Lab to try and lighten up the shadow areas at least a little bit. Then on the second pass I used a B Mask to darken the sky. The noise level was unacceptably high (so in the real world I might have opted for a different mask). I cheated a bit and used a heavy dose of Noise Ninja to knock out some of the noise.
