Sun Moon Lake Temple View
It is referenced at page 4 of the weeks assignments. It says you must uninvert before a K mask before clicking the apply button. The problem I have been experienced which I think is attributable to this bug is that you make the adjustments in Curvemeister and then hit apply and the adjustment occurs on the opposite side of the mask (i.e. in both examples the non-sky areas). I can't tell when I need to univert (this seems to have happened to me whether I have inverted or not) so it has been pretty much guesswork as to what is going to happen after I hit apply.
