Also 3.0.12 did not ask to uninstall 3.0.8. It did ask me if I wanted to keep my backup. It just installed on top. I assume that is OK. It reports 3.0.12 in help about, and the plugin date looks OK. If I uninstall 3.0.12 everything seems to be left installed (it still works, everything still present bar the back up I asked to have removed, assuming one was left to remove).
Defect: 3.0.12 minimize and resize don't work
On my XP SP3 box, unlike 3.0.8, this CM Elements beta only seems to let you close the window using the window buttons (giving you the return... discard options). It opens maximized, and I can't resize etc. Really painful even to report issues if I can't work with 2 windows without recourse and the task manager/switch to. Any chance of a rebuild/quick fix?
