Another beta in the usual location:
I believe this version fixes the problem Greg found yesterday with pins dragged from the pin palette.
Beta 3.0.12
I'm not sure what you did but.....
Everything seems faster and all of the pining functions I have tested seem to be working correctly.
The installer worked fine, the pins and SHN seem to be working great.
In fact It looks like you cured a slight glitch that was in the program for a few previous beta versions where the SNH had a double circle on the image as if there were two points selected.
I'll keep beating on it but so far Very Nice.....
