Advanced work flow - Pinning Skin Tones in Curvemeister
This board is for the November 2008 CM101 class.
Postby ggroess » Wed Nov 26, 2008 4:00 am
As I work on skin tones in CM one of the biggest hurdles is knowing what "Skin Pin" to set.  I have created a few resources for you to use and build upon.
Lastly is the work flow...
