St Vitus
This board is for the November 2008 CM101 class.
Postby mikemeister_admin » Sat Nov 22, 2008 3:42 pm
Two versions in Lab,one "freehand"the other shadow,highlight,neut.In the second image I can remove a bit of blue from the stones using Blue channel of RGB,puts a little yellow in the light colored stones,like image one.
Postby ggroess » Sat Nov 22, 2008 4:50 pm
I think I like image 1 better..there is more range in the stone...
Thanks for loading the acv files.
