Bug Status
Postby -default » Thu Nov 06, 2008 10:47 am
Status of beta bugs
Version 3.0.10
  • Shadow, highlight, and neutral points are sometimes created as ordinary sample points.  Status: open
  • Using the delete key curve points does not work.  Status: open.
  • Curvemeiser3.8bf does not get copied to PluginFilters folder for certain Vista installs  Status: fixed in 3.0.11
  • "boing bug": keyboard shortcuts fail to work, depending on the last window that was clicked on.  For example, the mask on/off toggle works if the preview window is active, but not if one of the curve windows has been clicked on recently.  Status: open
Postby mikemeister_admin » Sat Nov 08, 2008 7:48 pm
I was checking out which window caused the ctr-g shortcut to stop working, and found if I open CM and select a mask in RGB the shortcut works. If I do nothing but change to another mode(and not leave the preview window) it stops working. Though the icon will toggle. So I don't know if that means it depends on the last window selected...
Gloria
...I just found that I only need to click back in the preview window to get the shortcut to work, no matter what window, or mode I am in. If I click back in the preview window, the shortcut works again.
