Delete appears to not remove a point from the curve
Postby ggroess » Wed Nov 05, 2008 9:09 pm
Delete does not remove selected point from the curve.
I have even tried to drag them off the grid and they persist.
I am working on an RGB image and cannot remove a point from the G channel currently.
Postby -default » Wed Nov 05, 2008 10:32 pm
Wow - another big one.  Thanks, Greg.
Postby ggroess » Thu Nov 06, 2008 2:14 am
I live to serve...LoL
Postby -default » Thu Nov 06, 2008 10:04 am
Darn - I can't get this bug to happen on my CS3/XP32 or CS4/Vista 64 system.  Hope this is not just a Vista 32 thing.
BTW, I'm posting a bug summary on the bug board:
http://www.curvemeister.com/forum/index.php?topic=2225.0
Postby ggroess » Thu Nov 06, 2008 2:28 pm
this was on an XP system...I have been able today to drag them off the grid.
Delete does not remove them from this system..I'll test Vista later today.
j2e4a8n
Postby j2e4a8n » Thu Nov 06, 2008 6:57 pm
It appened to me too on XP pro version cm 3.0.8
Postby -default » Thu Nov 06, 2008 10:22 pm
Thanks - I'm confident that I can fix this one when I am able to make it happen.  Is this an intermittent thing that happens, or does it happen every time?
Postby ggroess » Thu Nov 06, 2008 11:40 pm
pretty consistent in XP.
Postby -default » Thu Nov 06, 2008 11:55 pm
Hi Greg,  For the life of me I can't make this happen on my system (CS3, XP Pro).  Could you do a video?
Postby -default » Fri Nov 07, 2008 12:35 am
Thinking about it some more.  Dragging points off the curve handled in the curve control itself, which lives in a file called CurveCtl3.ocx.
I'm enclosing a program that will create a curve control in the right half of the window.  If the delete problem happens that will narrow the problem down to the curve control itself.
If you have CM2 installed, you will also see a curve in the left window.  That curve should work normally, if it shows on your system.
