How To Post Images to the Forum....
This board is for the November 2008 CM101 class.
Postby ggroess » Tue Nov 04, 2008 9:39 pm
Everyone,
  • Please remember to re-size your images to fit under the 200kb limit per image.
    You can have up to 500kb per post but no more than 200kb per attached image.
  • If you are new to image re-sizing you can use the PS or PSE "save for web" command under the "file" menu to help you re-size the image.  You might want to keep the overall image size to 1024X1024 as upper limits for both horizontal and vertical sizes.  Just set the quality value to give you an Image that is less than 200kb.
  • You might want to look into a freeware printscreen program.  I use Gadwin Printscreen
http://www.gadwin.com/printscreen/ version 4.3 is free. This will help you capture screens that include the curves windows and to help us work with you on your images.
