3.0.10 Install bug
Postby ggroess » Fri Oct 31, 2008 1:09 pm
I had to manually copy the 8Bf file into PSCS and PSE filters folders.  I did un-install the 3.0.8 build but the 3.0.10 install seems to place the file in the wrong spot.
Postby -default » Fri Oct 31, 2008 8:03 pm
3.0.10 does not sound ready for prime time!  I've tried to recreate this on my system and of course it works fine...
You're CS4 and Elements 6, right?
Postby ggroess » Fri Oct 31, 2008 8:24 pm
Both PSE 6 and 7 and CS3. PSE7 arrived today...
I have un-installed and re-installed...the only thing that fixes it is a manual copy to the Pluginsfilters folder.
remember I have Vista....
Is is an installer issue rather than program??
Postby -default » Fri Oct 31, 2008 9:47 pm
It's an installer issue.  The funny thing about it is that, although I added check boxes for PSE7 and CM4, the underlying configuration is the same as before.  So I'm scratching my head on this one for now.
Postby ggroess » Mon Nov 03, 2008 10:26 pm
Just installed on a XP system with no issues.....
I'm begining to think Vista hates....
Postby -default » Mon Nov 03, 2008 11:13 pm
Oh no no no, not the Vista!
I'm playing with Vista now, so we'll see if Vista hates both of us, LOL.
