London calling
interesting twist on this using the K channel. I found it still to have a slight cast. I'm guessing you probably set the neutral on the gray face of the building. It left the paper with a greenish yellow cast.
When I set a neutral on the paper from your image the gray blocks only changed a tiny bit. Still it is a subjective adjustment from my perspective so you can ignore it if you like....
