underexposed with a flare
j2e4a8n
Postby j2e4a8n » Mon Oct 20, 2008 3:41 pm
Well, I tried a lot on this one.
Check for the floare when corrected for exposure
Postby imported_ganna » Mon Oct 20, 2008 5:56 pm
CM and I touched this :)
Postby ggroess » Mon Oct 20, 2008 6:19 pm
Very nice...
Jean,
The flare might have to be tackled on the individual channels...
j2e4a8n
Postby j2e4a8n » Mon Oct 20, 2008 8:06 pm
See the kind of oblique window above the guy legs
Can we get rid of that?
Postby mikemeister_admin » Sat Oct 25, 2008 10:50 pm
Nice work Ganna.I selected the group and the shadow and pulled down the brightness,result looks kinda photoshopped.Maybe some sort of selection and gradient fill,problem is flare continues along shadowline and back to camera.
Postby imported_ganna » Sun Oct 26, 2008 5:38 am
It will take lots of time and patience and I still don't know what result to expect. Can try with the clone stamp tool to get rid of the hard transition between light and dark but I do not know of an easy way to do it.
Postby ggroess » Sun Oct 26, 2008 4:19 pm
You could try:
Split channels from the channels pallet.  Edit each separate image in B&W to remove the flare in gray scale.
Then copy each channel back into the original replacing the old flared channel with the new repaired channel.
The commands are just copy and paste using the channels pallet and if you take a few minutes you can get a fairly good repair.
More time and effort would only help..  I have 5 minutes into this...
Postby imported_ganna » Sun Oct 26, 2008 5:05 pm
Thanx Greg, this is a new method to me. Will give it a try.
