Advanced Workflow - Pinning Skin Tones in CM
Postby ggroess » Mon Sep 29, 2008 1:06 pm
This one is still a bit new.
As I work on skin tones in CM one of the biggest hurdles is knowing what "Skin Pin" to set.  I have created a few resources for you to use and build upon.
The next is a set of pins that I have posted in the Pins Area. Pins.txt needs to be copied to you pins folder.
Lastly is the work flow...
Your thoughts and questions will help me distill this down to a better work flow...so let please post reaction to this...
