Hi,
When working with curves in Photoshop, I can Control-click the image to add a point to the composite curve, and Shift + Control-click the image to set a point to the channel curves. Does CM have similar keyboard shortcuts?
Question: how do I add control point to the curve by clicking on the image?
In CM you can righ click on the image and choose "mark" This will place a marker on the curve that you can adjust from there. You can convert the mark to a pin or just click on it to set the point as a control point.
Shot 1 is the image and curve after a right click "mark"
Shot 2 is clicking on the mark to create a point.
