Hi All,
Here are my RGB and Lab attempts at fixing the Merry-Go-Round image. I like the RGB one better--and it was far easier to accomplish than the Lab (which I never was satisfied with.
All comments welcome.
Jim
Jim's Week 2 Merry-Go-Round Images
Jim,
Did you attempt to use the wizard on these?? If so you might want to turn it off and try the "Lizard Tail" to see if you can bring up the shadows. It is actually easier to do in LAB since the color is separate from the brightness.
Read this article and see if you can apply it to the Image.
http://www.curvemeister.com/wiki/index.php?title=Special_Curves:_Lizard_Tail
RGB should actually be harder to do this on...
