How to post images to the forum.
Postby ggroess » Sat Sep 06, 2008 2:01 pm
Everyone,
  • Please remember to re-size your images to fit under the 200kb limit per image.
    You can have up to 500kb per post but no more than 200kb per attached image.
  • If you are new to image re-sizing you can use the PS or PSE "save for web" command under the "file" menu to help you re-size the image.  You might want to keep the overall image size to 1024X1024 as upper limits for both horizontal and vertical sizes.  Just set the quality value to give you an Image that is less than 200kb.
  • You might want to look into a freeware printscreen program.  I use Gadwin Printscreen
http://www.gadwin.com/printscreen/ version 4.3 is free. This will help you capture screens that include the curves windows and to help us work with you on your images.
    Postby mikemeister_admin » Sun Sep 07, 2008 7:52 pm
    Hi Greg
    Beginners teething problems: am using gadwin to print the screen, but the file is 5MB. How do I reduce it? Thanks
    Postby ggroess » Mon Sep 08, 2008 3:53 pm
    There are options in Gadwin to reduce the size.  Check the "destination" tab in Gadwin for your specific printer and file output options.
    I tend to scale them down a bit and keep the size under 1024 on any side.
    Make sure you are not scaling the image up.  that can happen just as easily.
    Sometimes when I grab a whole screen I have to use PS or PSE to resize after the fact.  usually if you use the rectangular selection tool and only clip the parts you want you get much smaller files.
    Postby mikemeister_admin » Mon Sep 08, 2008 9:31 pm
    Thanks
