Temple Figures
OK, I made another run at this image. I set myself a goal of bringing up the darker figures in addition to darkening the bright portion. To do this, I first used the S channel as a mask and then lowered the bright end of the L channel. Next I wanted to mess with the lower portion of the L curve, but with the mask in effect I could not do anything useful in the dark areas. So I exited CM, then flattened the image, and then reopened CM and reset all the curves so that I could regain control of the entire tonal range. Is there another, easier or better way to do this? In other words, can you get rid of the mask in some other way once it had one its job?
-- Russ
-- Russ
