Hello,
I have very strange problem in CS3 using Curvemeister. Whenever I do something in Curvemeister (and it doesn't matter if I save it or discard) and then I exit then simply my MOVE TOOL in CS3 doesn't work... better say it works but when moving any object in any layer I can't see it moving until I release the mouse button. The object changes position but I can't see it moving which is relally frustrating. It really does Curvemeister because if I reset CS3 using the ctrl+alt+shift then it works perfectly until I do something in Curvemeister again:-(
Any suggestion?
Thank You!
Ondrej
Move Tool in CS3 (don't see objects when moving after using Curvemeister)
Thanks for reporting this. I'd noticed this happening on my system, but chalked it up to a Photoshop related problem. In fact, resetting Photoshop's preferences seems also to fix the problem, but perhaps it's just a matter of restarting Photoshop.
It's on the bug list, probably not for the next beta release but I'll keep you posted - thanks again.
