I did this in 3 stages: Firstly opened in RAW and with fill-in light brightened the dark bakground. Then into CM and set the shadow, highlights and skintones and save. Reopened again in Lab and choose a mask in H. I then oversaturated the image but reset the neutral and tried to keep skintones normal.
Mike/Greg it seems that CM runs happier when in 8 bit. Sometimes battles a bit when in 16 bit, for instance mask would'nt load and process is slower. When in 16 bit it crashes when going for smart filter.
Taipei-toys
