Tassels
Postby mikemeister_admin » Sat Aug 16, 2008 5:11 pm
First picture is according to the video.Second picture is attempt to clear up red cast on stone.Using red channel I tried the get some red back into the wall.
Postby mikemeister_admin » Sat Aug 16, 2008 7:21 pm
Here is my attempt to mimic Mike's video solution:
  -- Russ
Postby ggroess » Sat Aug 16, 2008 11:00 pm
Hi!...
Both of you can solver the red halos by loosening up on the mask.
The tighter the mask the more likely you are to leave these areas behind.
As you adjust the mask to make it completely black, back off a bit and see if the halos go away..
Postby mikemeister_admin » Tue Aug 19, 2008 6:13 pm
Yes,as I widened the slope of the mask I could control the reflections better.Problem is tassels look black but are very black-green.
Postby ggroess » Wed Aug 20, 2008 12:14 pm
You can move the center of the A curve a bit to make the A and B channels equal.
Set a hue clock on the black and then slowly move the center of the A curve until the A and B values are equal.
Or
If the black is saturated enough you could ignore it unless it shifts the rest of the scene green blacks are kind of ugly..The hue clock values are more important than which direction they are pointed though.
Postby mikemeister_admin » Sun Aug 24, 2008 3:45 pm
Here is another attempt.  As you suggested, I used a less aggressive slope on the mask.  Is this better?
  -- Russ
Postby ggroess » Mon Aug 25, 2008 11:20 pm
Bring the dark end of the mask in a bit more and leave the highlight end alone.  It seems like you are close but not quite there....
Postby mikemeister_admin » Tue Aug 26, 2008 10:27 pm
OK, one more time - did I go far enough?
  -- Russ
Postby ggroess » Wed Aug 27, 2008 2:58 am
Russ,
Tough call.  I would say no... but I sense you are getting frustrated with the image...
Can you again post the ACV file and I'll take it apart on this end and see if I can help you more...
The maroon shadows are what is setting me off...most of the shadows are good on the wall but the ones under the tassels are still hanging in there..
Postby mikemeister_admin » Wed Aug 27, 2008 3:22 am
Greg:
Here is the ACV for my version.  I am looking forward to your insights into why I am not getting the desired result.  This exercise has been quite a challenge.
  -- Russ
