Tiger
Postby mikemeister_admin » Tue Aug 12, 2008 11:38 am
Well I just could not get on with Lab - especially had a problem with the near blown tree turning yellow.
I much preferred rgb - and also thought a wee crop would help the composition!
Postby -default » Tue Aug 12, 2008 11:45 am
Yes, the foreground is so blown out that it should be ignored from a color correction standpoint.  Cropping, is probably the best choice, since bright areas near the edge of an otherwise dark image is considered a defect in composition.  Burning in or otherwise darkening the lower edge is another alternative.
