This one is a bit new.
As I work on skin tones in CM one of the biggest hurdles is knowing what "Skin Pin" to set. I have created a few resources for you to use and build upon.
The next is a set of pins that I have posted in the Pins Area. Pins.txt needs to be copied to you pins folder.
Lastly is the work flow...
Your thoughts and questions will help me distill this down to a better work flow...so let please post reaction to this...
Pinning Skin Tones - Advanced Work Flow
Greg, this is amazing. Can I give you a pat on the back! 8) Thanks a lot; if this was the only new thing I learned from this class it was more than worth it. I presume you will also place a video clip?
Interesting that you did it in RGB
I can do it in LAB as well.. I did it in RGB so that I could use multiple skin pins one in the highlight and one in the shadow.
LAB will only allow 1 active pin at a time. I would have to take 2 passes at a LAB correction I think.
If I am certain about the Pin I use LAB. If I am shopping around for a good match I go RGB for the Skin tones part.
I wanted to get some of the guess work out of the process. The Pin samples in CM are small and Mike is looking at ways to address this. I find that if I choose the wrong tones to make the gradient it is very easy to see that I have a bad match and I can go back and choose different set of pins to use.
I have experimented with using different highlight and shadow pins at the same time as well For instance sometimes I use an Asian pin with a Caucasian pin. It really depends on the tonality I am looking for.
