I think because everything is so close together on the curves, this is impossible to get 'right' for every part of the image.
I've got 2 renditions
1st attempting to pin each face
w3 street scene
You might have overworked this one...
I try to keep it simple. Set a Skin 8 pin as shown in the attached image and then set a neutral in the shadow. after that I just moved the skin 8 pin around a bit to get the other two faces reasonable.
If you wanted you could take a second pass at the image in LAB for saturation.
Gre
Gre
