An interesting discussion of blue sky by Gernot Hoffmann
http://www.fho-emden.de/~hoffmann/skyblue14072008.pdf
Blue Sky - Gernot Hoffmann
That's an excellent piece of work. I'm currently post processing a batch of photos I took at a recent airshow. In typical UK summer fashion, the sky was clear blue one minute and overcast cloudy the next, with periods of broken cloud in between. Cloud is quite easy to work with in CM - texture comes with a steepening of the lightness curve in the right place. Blue skies are a lot harder, looking just plain wrong if they're not absolutely right. Looks like I have my weekend's homework set. :)
Yes, I found it interesting, but I'm confused over a number of little points.
a) I dont use the S/H tool, but if my eyes do not decieve me, it makes halos all over the place - is this correct?
b) In example 2, when he starts using the BlendIF sliders to limit the change to just the sky, he changes both the underlying layer as well as the top one. As far as I can see, it just needs the Yellow lowering to around 116. What am I missing?
Of course we are lucky using CM in that we can pin a sky to get realistic results!
Bearing the above in mind, the attached photo has an almost exact Brodie sky match in the top left and a very noticeable decrease in saturation towards the horizon (as pointed out my Mike).
So would you like to have a bash at improving this image? (I had thought of posting it as an example for the current course, because we play with 'bad' images, but not often with moderately normal ones).
