Class 2 submission: Fruit Vendorh
Postby mikemeister_admin » Thu Jul 31, 2008 4:46 am
Walt Smith
Postby ggroess » Thu Jul 31, 2008 4:14 pm
The colors look great but the frame around the window is stainless steel, as much of the green cast as possible should be corrected out of the image.  Try this one in RGB and LAB where you can set an effective neutral.
Postby mikemeister_admin » Sun Aug 03, 2008 2:52 pm
Here is my corrected fruit vendor window.  I had a hard time with this one, and had to dink around with it quite a bit to get the intense colors in the fruit I was after, without getting a strong color cast in the metal frame.  I like where I finally ended up, but it may be too over the top.
  -- Russ
Postby ggroess » Mon Aug 04, 2008 7:09 pm
You might need to brighten it up a bit.  The overall color looks good but a tad dark...ok a bit more than a tad...how about two tads...
Brighten it up a bit and I bet the fruit looks better...
