The Bear
Postby mikemeister_admin » Wed Jul 30, 2008 6:32 pm
Well, I'm amazed, I think I did a much better job in rgb than lab.
Mainly because I could not get rid of the yellow earth when setting a neutral in lab.
I also failed to remove one of the A channel neutral pin Greg - it would not be carried off the dialog and there was no option to delete it.  What am I doing wrong to release one of the pins on a curve?
and the worse lab one
Postby mikemeister_admin » Wed Jul 30, 2008 6:46 pm
nope - I've blown his forehead - concentrating too much on the fur
so this rgb is a little better
Postby mikemeister_admin » Sun Aug 03, 2008 3:12 pm
Here is my attempt at the bear.  I thought Mikes Lab version made the grass a little too fluorescent, so I stopped a little short of that.
  -- Russ
Postby ggroess » Mon Aug 04, 2008 7:31 pm
Russ, your bear looks fine...good work...
Zog,
Since the bear is the main focus for the image, I was OK with the background being warm.  I found only a few areas where the L hit 100.  there was still color in the fur at that point...
my version is attached...note the saturation and the heel of the lightness curve.
Users browsing this forum: Bing [Bot] and 13 guests
