Example8 -temple
Postby mikemeister_admin » Tue Jul 29, 2008 4:17 pm
Most interesting, but probably not something one can do with many images.
I have a question - the idea of locking all 3 channels together is very useful - can I do it with any pinning?
And having got 3 pins, can I release one?
Oh BTW, I attempted to follow the instructions (for once!)
Postby ggroess » Tue Jul 29, 2008 6:32 pm
It really works best in RGB,  Lab will only look at one pin at a time.
You can remove any pin from the curve by dragging it off.
Many times I'll do the adjustment with the linked pins, find what I want to fix, and remove the linked pin in favor of a "mark" and manual adjustment to only the channels I want to adjust. The "Linked Neutral" is telling RGB to make that area a neutral.  If you use a color pin you can adjust the "mode" of the pin.  you just have to play around in there a bit...
