Looking back through the 2 courses I've done with CM, there is a bit of a lack of photos with faces and bad WB - I wonder if your new pinning examples will help rectify that. I was playing with some odd images and found that my understanding and curving in rgb where there are bad casts is not very good and that's an area I'd like to improve.
BTW - where is everybody? I can only think that they are too busy doing other things - well I suspose there is more to life than CM and here in the UK we are actually experiencing summer! - but I had expected to see more submissions.
Content request
I too am surprised by the slow boards...
I will be bringing some new faces to the skin tones module I am going to try to introduce. The problem with faces is the willingness to post a portrait to the web for everyone to down load. We do it for many reasons but when we post it for others to download it gives everyone pause....
Oh, all these images are so interesting - I'm not a great pinned (!), but this time in rgb I set shadow/hilight and then pinned the left cheek at skin 1 and the lower part of the neck at skin 4.
This seemed to flatten the contrast a touch, so I used these 2 points in contrast pin mode to try and give a bit more depth to the skin colours.
I also NeatImage + FocusMagic (definitely required) before I started.
To show you how effective FM is, the first image has one side focused.
