Common mask uses
If your question is not covered in the manual, please post it here.
Bulldoggie
Postby Bulldoggie » Fri Jul 18, 2008 1:46 am
As you know, there are a number of moves Dan Margulis and others do that make heavy use of masks in their moves. With all this new masking capability it sure would be nice to have some examples of using CM to accomplish the moves - focused more on showing the mechanics of using the specialized masks in the CM than why you'd use them.
Postby -default » Fri Sep 19, 2008 4:22 pm
Thanks for suggesting this.  Right now the main example is the sky darkening one in the wiki, and there should be more.
Return to “Missing Manual Pages”
