I have a feeling I once heard that we could have the Carte showing in a separate pain, rather than replacing the image - but can not see how to do it?
Is there a way?
Mask Carte
No Mike,
I wasn't after a large mask in it's own window along side the image window - I've only a small 1600x1200 screen - not 2 screens.
What I thought I'd read was that it was possible to show all the masks (before selecting one) in its own window - similar to being able to move & resize the Curve window.
Thanks Mike,
I thought it was something like that, but clicking on the 2 mask icon next to the pin icon does nothing, whether or not I'm showing the masks or not. I just get all the masks replacing the image.
Similarily the menu item Set Mask>Show Mask Carte does nothing.
The only icon which works is the one left of the Set Mask menu or Set Mask>Show Mask
I have a 'handle' to move the taskbar around, but I can not find the mask one.
Chris
Chris
Hmmm - this sounds like it might be a palette location issue. If you are comfy with regedit, try deleting the keys under
HKEY_CURRENT_USERSoftwareCurvemeister.comCurvemeister3
This will reset your palette locations, and toolbars to their defaults. If that works, I may need to change the installer to do this reset automatically.
ah ha- dangerous thing to do!
Because now it will not register - comes up with
http://www.curvemeister.com/products/Curvemeister3/ 'Page can not be found'
luckily I took a copy first !
So I tried just deleting all but the ProductURL, SerialNumber, UserCompany, UserName & Version
but that did not help.
I actually have the following (not showing the serial number!)
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINESOFTWARECurvemeister.com]
[HKEY_LOCAL_MACHINESOFTWARECurvemeister.comCurves 2 Demo-Install]
"DontShowSN"="1"
"Directory"="C:\Program Files\Curvemeister.com\Curves 2 Demo"
"Version"="Demo-2.4.10"
"UserName"="Chris"
"UserCompany"=""
"helpURL"="http://www.Curvemeister.com/suppport/curvemeister2/help/"
"updateUrl"="http://www.Curvemeister.com/downloads/cmdemo/"
"productURL"="http://www.Curvemeister.com/product/curvemeister2/"
[HKEY_LOCAL_MACHINESOFTWARECurvemeister.comCurves 2-Install]
[HKEY_LOCAL_MACHINESOFTWARECurvemeister.comCurves 3]
[HKEY_LOCAL_MACHINESOFTWARECurvemeister.comCurves 3Default Settings]
[HKEY_LOCAL_MACHINESOFTWARECurvemeister.comCurves 3-Install]
"UserName"="Chris"
"SerialNumber"="**********"
"UserCompany"=""
"DontShowSN"=dword:00000000
"Directory"="C:\Program Files\Curvemeister.com\Curvemeister_3"
"Version"="3.0.8"
"helpURL"="http://www.curvemeister.com/support/Curvemeister3/help/"
"updateURL"="http://www.curvemeister.com/support/Curvemeister3/"
"productURL"="http://www.curvemeister.com/products/Curvemeister3/"
"SwatchDir"="C:\Documents and Settings\All Users\Application Data\Curvemeister.com\Curvemeister_3\Swatches"
"HistoryDir"="C:\Documents and Settings\All Users\Application Data\Curvemeister.com\Curvemeister_3\History"
"FavoritesDir"="C:\Documents and Settings\All Users\Application Data\Curvemeister.com\Curvemeister_3\Favorites"
"LibraryDir"="C:\Documents and Settings\All Users\Application Data\Curvemeister.com\Curvemeister_3\Library"
"SharedDir"="C:\Documents and Settings\All Users\Application Data\Curvemeister.com\Curvemeister_3"
"OtherDir"=""
"AutoUpdater"="C:\Program Files\Common Files\Thraex Software\AutoUpdator\AutoUpdator.exe"
[HKEY_LOCAL_MACHINESOFTWARECurvemeister.comCurves 3e-Install]
which should I remove?
Chris
"DontShowSN"="1"
"UserName"="Chris"
"UserCompany"=""
"UserName"="Chris"
"UserCompany"=""
"Version"="3.0.8"
"OtherDir"=""
Chris
