I've just updated to 3.0.8 and the History (curve) folder has moved to Document & Settings
Dont quite see how to place it somewhere else
Thanks
Chris
History folder location
Yes, the History, Swatches, and other folders have been moved to Docs and Settings, as a salute to Vista, which does not like modifying files in the Program Files folder.
If you would like to move the history folder, this can be done by changing the registry with regedit. The name of the key where the folder names are located is:
HKEY_LOCAL_MACHINESOFTWARECurvemeister.comCurves 3-Install
As it stands now, unfortunately, the installer will reset this each time you do an installation.
I tried having the old version of the folder be retained, but this caused some rather tricky support problems with pins disappearing or being overwritten, and then having to guess where a particular customer's pin files were located.
