Hi Mike,
I'm trying to use masks and I wanted to soften the selection using 'light' but when I did it I got this message:
'Could not complete C3 Command because DVPDoc::Read Pixels from level: Read Pixel Proc error: Stop'
I verified that this was happening by repeating the process several time (yeah, I know...definition of idiocy).
I'm taking Sarah's class and I'm having trouble with the masks commands in general. When I follow the class example everything is fine but if I try to use something other than LAB to make my mask it doesn't make it to CS3. I just get a totally white mask - i.e. loose my selection. I see that other people are having problems with this too. I hope you can fix it in 3.06. It's a really nice feature.
j.
Trying to soften selection error
Hey Jodz,
Are you doing the paste part of the process correctly?
remember the general process is create the mask ; use the copy Icon to copy it to the clipboard; Close CM and go back to PS or PSE.
Highlight the mask layer and alt click on the white square
I use The Edit menu to paste the channel into the mask. Edit > Paste.
You should have shot2.jpg when you are done...
Jodie, I'm having problems getting your exact bug to happen. I've tried various sized images in 16 bit mode, including larger than 12 megapixels. If you can give me the bit depth and size of the image that will give me a better shot at recreating the problem.
Meantime, there is a similar bug involving selections in 16 bit mode. I'll work on that bug and see if the one you found is fixed at the same time.
