Caterpillar on Mask Curve?
roy
Postby roy » Mon May 26, 2008 10:03 pm
Hi Mike and all,
I've been really appreciating all the cool things I've found to do with CM3 - its great!
One thing I've been doing is using a Hue mask to apply adjustments just to a range of colors.  It can involve a bit of guesswork though - if I'm making the adjustments in Lab, say, and want to mask out a range of colors, I'm not sure where that range is (especially as the numbers along the x-axis of the hue mask are different to the numbers on the x-axis of the H-curve in HSB color space, but that's another story!).
So I was wondering how easy it would be to put a caterpillar on the Mask curve just like on the other curves?
take care
Roy
Postby -default » Tue May 27, 2008 10:34 am
Thanks, Roy.  This is a feature that should be in there.  I'll see how hard it would be to add.
