Installed:
CM 3.0.5
PE2
Vista Home Prem
When trying to install CM 3.0.7 for PE only, the installer retains my name and serial number, but when I hit return, it says I didn't enter the information correctly.
The PE 3.0.7 installer retains but rejects name and serial number
Hi Teffy,
This was my mistake - you are actually a registered owner of the full Photoshop + Elements version. So download the other version and everything should be fine. Please let me know if you find any other problems.
Thanks for being one of the pioneers with this beta. I'll work on a way for the installer to give a better error message.
really??
I have home Premium on my main desk and my laptop..everything has been very nice so far....
Are you running PSE 2 in windows XP compatibility mode??
You can go to the .Exe file in the file manager and right click on it and set the properties for the OS you need.
Try XP compatibility mode....
I installed CM 3.0.8 (full version) which went without a hitch. But, when I run Elements 2, I see only Curves 2.0 under Filters> Curvemeister. I tried running Elements in compatibility mode (both XP and Win2K), but I still cannot see Curves 3.
So, I downloaded and installed a trial version of PE6, restarted Vista, and installed CM 3.0.8 again - this time the PE6 box was checked. I start PE6, open an image, but don't see CM on the Filters menu. Same result if I run PE6 in XP compatibility mode.
Any ideas?
Any ideas?
I noticed this too...
The real issue is that PS and PSE flag the folders as read only and the installer is not catching this. When I went to Program filesAdobePSEPluginsFilters and set the rights to the folder to be NOT read only the installer worked...the same for PS.
I am an admin on the Vista PC and it still does not allow this.
When you set the folder flag to not be read only it works just fine.
I was re-installing last night because my PSE and PS versions did not match...
