Using w/PSE 5 -- can't find it CM!!
I purchased CM last night - downloaded and installed it -- everything seemed to be fine. It asked during installation if I wanted it to use with PSE 5, which I chose. It was late, so I thought I would get started with it in the morning. Now I cannot figure out how to initiate the program. In PSE 5 I cannot find it anywhere -- other add-ons I have (ie Noiseware) appear at the bottom of the filter menu or in the Artwork & Effects menu) -- and in looking at my c:programs/adobe/pse 5 I don't see it in the plugins anywhere - CM is listed separately in the programs list. I do have CM in my "programs" listing - but the only options are check for updates, help, CM clock and uninstall - no where to initiate the program. I'm sure I have missed something important here --- as I am a rank amateur with all of this. Any help will be appreciated.
Hi momatx,
Greg has covered the bases here - check the Plug-ins/Filters folder he mentions to see if the curvemeister3.8bf file is located there.
There is also a program called AcrChecker that will list all of your plugin information. I would be interested in what caused this problem because I am re-working the installer to be more automated.
