I tried this out because well I can.....LOL
Here is what I did. I opened an Image, Created a copy of the background, Converted Both to Smart Objects, Opened CM on both and made adjustments. (Shot 1) The I went for Broke to see what options I had access to...(Shot2) I right clicked on the CM part of the Smart Filter and chose the edit blending options.
The screen "Flashed" the CM program to the front for less than 1 second. Then it went back to the PS desktop. The program was locked up, could not be recovered. I had a mouse but the program would not respond to any input.
No error Messages.
No mouse clicks could get me out of it.
I had to Ctrl-Alt-Del to start over.
Smart Filters Bug
I wasn't sure what you were up to until I tried this, WonderGreg. And it worked fine for me, and was incredibly cool as well. I may have done something a little differently; I made two background copies, converted them both to smart objects, modified them in CM, went back into PS and selected edit blending options on the CM smart filter. From there I changed one filter to burn, another to luminosity. Then I went to the layer blending mode of the top layer and adjusted the sliders a little. It all worked as one would hope:)
Very interesting. I will definitely be keeping this in mind.
G
G
Greg/Georgie, sorry about that. At first, I thought maybe you had to leave a background layer intact, but I then tried it exactly as you set it up, and it still worked fine. How 'bout you be the brains, and we will try to follow through in practice? Don't know quite where that leaves you, Mike... I guess the genie in the bottle.
