Curvemaster 3 does not appear in PSE6 Filter menu
Postby mikemeister_admin » Thu Mar 06, 2008 5:34 am
Dear folks,
I downloaded the trial version of CM3 and installed it, but the Curvemeister filter
doesn't appear in the Filter menu of Photoshop Elements 6.
I tried copying the files listed below from "C:Program FilesCurvemeister.com"
into the PSE6 plug-ins folder, but that didn't help:
    CrashRpt.dll
    crtdll.dll
    CurveCtl3.ocx
    dbghelp.dll
    tips.txt
    zlib.dll
Of course, I've launched PSE6 multiple times.
Best regards,
Patrick
Postby ggroess » Thu Mar 06, 2008 4:23 pm
Do you also have Photoshop installed?
the default install will see Photoshop first.  Try re-installing and make sure the directory lists Photoshop Elements.
Postby mikemeister_admin » Fri Mar 07, 2008 4:59 am
Dear Greg,
Yes!  Is my face (255,0,0)!  I guess I'm getting too cocky.
Thanks for helping a fellow human being.
God bless you,
Patrick
Postby ggroess » Fri Mar 07, 2008 12:59 pm
You are quite welcome...
You can have it in both PS and PSE just make sure you do not un-install when the installer asks you.  It will be placed in both filter directories and the common files are shared.
That is how I run it...
Users browsing this forum: No registered users and 66 guests
