When you like it , i can place or send the video files to Mikes adress with Yousendit.
I have a free acccount on Yousendit.
That means i can sent 100 MB at once.
So i have some lessons video's divided in parts like A-B-C.
You can download it till 7 days after sending.
The maximum download each month is 1 gigabyte.
I have reached now 15 %.
But over 4 days there is another month.
frits Egelie
p.s. see pictures
the video's are all .wmv files and easy to play
The video files
I am very interested in this!I went to their website and will probably sign on.GregM
P.S.thanks for all the work you did for this course,helped a lot.
Gremurphoto,
everybody can get a free or payed account.
When you pay you can do more.
but on this moment , i have sent nothing.
You can use there website for sending big files to other persons.
when you have sent one file or more, all peolpe who knows the downloadadress can download the files till 7 days after uploading the files.
so what will i do, sending the video files??
they are big and only with a very quick account you can download them.
for phone it takes very long time.
Frits, If I understand that you have volunteered I would be interested in receiving the video files for this class. Would it help if I sent a list of the ones most useful or is it easier to just send them all. I believe my provider has a limit of 10MB of data/mail. My profile contains my e-mail address. What else would you need. I am presently involved in another project so that I am only able to view this forum twice a day (morning and evening).
Thanks Joe S
Thanks Joe S
Thanks Joe S
what is voluntering ? I was busy to catch the video's in .avi files. So I have them, But .avi is big.
I converted them with Adobe premiere elements 4.0 to .wmv files.
I have tried this with a other converter, but the size is the same, but the quality is more bad.
So Adobe gives the best quality. The shrinking in size is about 6:1.
So i have them all converted.
I can send it to you with Yousendit.
I will place the download adress on this forum.
after that, it can be dowenloaded 100 times or by 100 people.
But, i have a free account on Yousendit.
That means i can send only 100 MB at once.
After the lessons , I have discovered that Mike changed some things in some lessons.
I thought lessons 2. He placed 4 new video-hints.
I have them, but not converted yet to .wmv files.
So i had to do that first.
I will start now by sending lesson 1-3-4-5-6.
p.s. you e.mail adress is hidden in your profile
p.s. 2 : what do you mean with 10 MB data/ email ? Is your e-mail box 10 MB ? With downloading that is no problem.
Have you a overall datatraffic of 10 MB ( i don't believe that) you have a big problem.
